Hello,
I really need some help here. I have a 1967 Galaxie XL convertible, 390 with an automatic. The previous owner said the directionals did not work and the flasher was making the tail lights and dash lights blink. I have replaced the directional cam and wiring harness, flasher, headlight switch as well as installing a new fuse panel. This problem continues! I have noted with the new headlight switch if I turn the Dome light all the way to dim, the flashing stops, but then the directionals don’t work (flash). This problem presents itself when the ignition is at accessory or the car is running. I have checked and double checked my work but cannot seem to find the problem. The wiring diagram is not crystal clear on this. Could the ignition switch be bad or the neutral safety switch?
Thanks in advance for any feedback
