I’ve got a few wiring questions. The main problem is with the turn signal wiring on my ’72 Mach 1. The previous owner “re-wired” the turn signal to bypass the switch. They taped a three-way switch on the side of the steering wheel and ran the wires from the switch to the wires after the fuse box. The thing is that when I put on the turn signal only the front bottom parking lights blink while the front and back sidelights, and taillights don’t blink or even turn on. My question is what do you guys think it is? I don’t have a multimeter with me today and I can’t find a good wiring diagram in my 72 factory manual. Any ideas or suggestions before I get back to this problem?
Second thing. Has anyone here done a auto to manual conversion? If so how did you rewire the neutral starter switch and back up light switch?
