63 500XL, 390. Appears to be all original. Car was hard to start…found the carb base gasket pretty well gone, hopefully replacing it (yesterday) will help.
Anyway, on to the electrical. Like I said, car appears original, so I believe that starter/starter cable/generator is original. I have already replaced both battery cables and battery.
When the battery appears fully charged, it will not crank the car as long as I think it should. If I had the crank the car for 8 seconds at a time, it will not do that even 4 times before the battery is useless. When I jump the Galaxie with a car putting out 13+volts, she starts right up.
I am contemplating several things: after replacing starter cable of course, replacing the starter with a newer/higher performance one that has a gear reduction set up to spin the engine faster with same/less volts used, and replacing the generator. I’m thinking of getting the generator rebuilt as an alternator, with the same external appearance, or replacing it with a one wire alternator.
To be fair to the car, I did note 13+v at the battery when it was running, but this was when the engine was running at a higher rpm…when I backed off on the rpm, I’m sure the battery was getting less of a charge. Also, I changed the generator belt when I first got the car a month ago, and I haven’t checked it again to see if it has stretched.
I’m open to any suggestions.
Thanks!
Gary in GA
Thanks!
Gary in GA
