I use plain black Moly Lube "paste" ... I've built about five engines over the past six years ...
I've dotted all the "I's" and I've crossed all the "T's" on some ...
Then I have just assembled parts and fired it up ...
(this usually being after an Initial Cam Failure on one of the "T" crossing and "I" dotting adventures.)
Moly Lube is great stuff and it will never leave the place you put it on
Most of the rest of the "priming the oil system" and "rotating the crank in 1/4 turn intervals" and the "use of special oils" and "whatever?"
Hasn't proven to me to be worth a rats rear end ... because most of the failures I've experience happend when I took special effort to do things exactly right ...
Then after A Failure and that frustration ... ... ... Then throwing caution to the wind on that stuff ... (not to be confused with failure to assemble the motor correctly to begin with)
I have had them fire and run flawlessly to this day using ZERO special Oiling "Techniques" on initial start-up.
Take it for what it's worth and I'm not saying "Don't do it." ........
But some of that stuff is akin to the "Witch Doctor" ...
Or so it seems to me.
<font size=-1>[ This Message was edited by: MonsterMach on 5/24/06 12:17pm ]</font>
