WHO MAKES THE BEST ROD AND MAIN BEARINGS THESES DAYS, I NEED A SET FOR MY 392
I've used Clevite, Federal Mogul, and King Aleccular. They all have worked well. Just check for proper clearance and anyone of them should handle the abuse.
I exclusively use the Federal Mogul race bearings. I use to use Clevites but they had tolerance issues with my where swapping bearings around would change my tolerances. I don't like that but the Fed Mogul bearings seem dead on each time.
My thinking is along Mike's way.I too have used several different brands of bearings,all which will wear,especially with severe duty cycles,regular and proper bearing maintenance will insure any bearing will work fine used in the proper enviorment.
