For some reason the 302 in my 1963 Falcon isn't sitting level. If I put the hood up, and looking at the car from the front, the engine sets 1 inch or more lower on the passenger side than on the driver side. When I put the car back together a few years ago, I didn't notice it and I don't recall if the engine was sitting this way when I bought the car. I replaced the motor mounts, and I'm positive I put the new motor mounts in (right,left side) the way I was told to by the parts store,so I don't think that's the problem. I was told that the mounts that are bolted to the frame on the early Mustangs had a right and left side to them, so I would asume the Falcon mounts are the same, is that correct? What could be the cause of this unlevel engine?
http://www.smallestparrots.com/falcon1.jpg
http://www.smallestparrots.com/falcon2.jpg
I notice mine is sitting unlevel the other day also. It use to sit level a few months ago
Could be the mount has given way. Some I've talked to put a bolt through the mount for support. The OE mounts don't hold up to the additional torque.
On mine the two angular pads have slots in them for ease of installation of the engine, with mounts pre-bolted on at the factory.
To be safe, you may have loosened one mount at a time to instll them.
I would think to just loosen both of them, then with a four by four heft the engine over in the engine compartment til it is straight. If it keeps settling back after giving it the bost, use a hydraulic bottle jack and place the base against the shock tower and push over the block. Then get under the car a torque the big nuts tight again. It may reallign things which attach to the transmission also.
They do slip afterall.
Wm.
