I have an 1987 5.0L I bought used. I converted it from EFI to carb.
Is it ok to block the heater core port at the water pump and at the intake manifold? I'm running this motor on a stand and the water temp keeps rising. The radiator is from a 5.0L mustang and I have a pretty strong fan blowing through it. The water pump is new. I changed the thermostat tonight and it still gets hot. Now I'm wondering if it is a problem to have the heater code ports blocked? Any comments are appreciated.
-Jeff
-Jeff
