Hey Guys, I know this has been asked but now that it's fricken hot outside here 100+ I don't drive the 66 much. It gets hotter (195) when I drive at highway speeds but goes back down to 180 when I drive slower. That's without the AC on so imagine what the temp would be with that on....super hot! Driving around without the AC on kinda defeats the purpose of it. I've got the stock radiator and water pump but I do have a heavy duty six blade fan on.....I took the clutch fan off since I don't trust it.
I know there must be a simple fix but I don't understand why there wouldn't be enough air flowing thru the AC condenser and radiator to cool at high speeds.....should I put the clutch fan back on? I just put in a new 180 thermostat and antifreeze and I see no leaks. This car has always done this when it gets hot outside and it sucks!
The car runs great other wise but maybe this is a clue.......when I turn the heater on to help cool her down faster, it doesn't help. I've checked the timing and it's dead nuts.
How do I check to see if the vacuum advance is working right....maybe it's not working at all.
