1 - 16 of 16 Posts
I am trying to get my 2000 V6 mustang engine to not shake as bad. I have replaced my motor mounts and it still shakes. Any suggestions on how to fix my problem?
Sent from my M865 using AutoGuide.Com Free App
When does it shake. Is it a vibration?
It shakes only when it is idoling. Once I rev up the rpms the shaking goes away.
Are they any kinda plugs that are suggested to be used? I do have a limited budget.
Sounds more like a vacuum leak. Do you have a vacuum gauge?
i dont know what you have done far as tuneup goes..???
throttlebody and idle air controller motor(iac) could be full of carbon...
sticking (iac) causing irratic idle ,engine shakeing....
get a spray can of carb cleaner and a toothbrush...
open throttleblade wide open give a good squirt of cleaner , then scrubb with toothbrush includeing backside of throttleblade,repeat untill nice and clean...
then remove (iac)motor from side of throttle body, give that a cleaning to.
you may need a new one, but try cleaning first...
this is what it looks like... BWD 50521 - Idle Air Cont Vlv | O'Reilly Auto Parts
then report back....;)
How many miles on engine? Is the check engine light on?
Discussion Starter · #13 ·
Thank you all for your help. I have fixed the issue. I replaced my spark plugs and the problem had been fixed. I was being general cause of wanting many dif posiblities for the problem. Thanks again.
1 - 16 of 16 Posts
