I'm a little stumped here. My engine has been smoking at high (both engine and rpm) speeds. I did a comp test the other day and I came up with all 8 cylinders being btw 175-180 and no unusual readings. This car smokes bad going from 3rd to 4th gear and continues to look like a tar kiln in 4th. What in the valvetrain could be the culprit? Or is it a seal leak large enough to make that much mess? I had about 7 oil droplets fall on the floor within an hour while doing the comp test, so I'm leaning that way. What seal could be that bad without being really obvious? The VC gaskets are ok and there is no sign of leakage there. The clutch doesn't slip so I don't think it is the rear main. Any help or even wild guesses would be great.
Thanks,
Bryan
Thanks,
Bryan
