Hey guys I had a big question..will the 750 lbs engine stand hold my 289??I heard they weigh bout 465 but I'm not sure if that's Juss the block alone or with all the Pistons,cams,heads and everything else..really appreciate your feedback thanks..
Sent from my HTC Sensation 4G using AutoGuide.com App
Heck yeah...I have a 750lb stand that I used to build my 351w and they weigh about 525lbs(complete) I had everythig on except the carb and headers. I would also use grade 8 bolts to bolt it to the stand.
So to answer your question, 465lbs is what a 289/203 weighs completely together.
You should be fine.
If you are buying one, I would recommend a 4 legged stand (base shaped like an "H") over one that only has 3 legs (base shaped like a "T".) More sturdy and less apt to tip.
You should be fine.
Absolutely, if you get into big blocks or complete engines that exceed 600lbs the "T" stands do get pretty wobbly.
