After 5 days of inactivity. buying wrong parts and general frustration, the car has FINALLY moved under its own power.
I have narrowed down the stumbling and engine shutdown problem to either the fuel lines or fuel pump eccentric. I bypassed the hard fuel lines and mechanical fuel pump w/electric pump and rubber fuel line. The engine started w/o problem and it actually idles better w/the electrical pump. This is only temporary solution since the engine will be replaced in a few weeks.
