I've been planning on swapping out the high mileage 302 in my Bronco with a mildly built up 351W,it's a fuel injected engine, so I know all the other stuff needed to put in the 351 (new maniold base, etc..) but my question concerns the computer controls. Will the original computer (EECIV) for the 302 work the same for the 351? I am reusing the emissions equipment and all other components, but I just wanted to make sure if I can reuse the computer too. Also, anyone know if it is a good idea to jump up a little in the injector department, since it is a larger engine. I appreciate any help and suggestions. Mike
YOu will be ok using the injectors and computer. THe 302 and 351 use the same injector. I have done similar swaps with no problems. The one thing I know you will have to redo is the exhaust. WHere the 351W is wider the y pipe won't fit.
