Hello
I currently have a 1966 Custom 500 with a 289. I want to swap it out for a big block. I am looking at a 429/460 swap for it. I am worried though, that not all the part will fit correctly. Will i have to make motor mounts for it since it did not come with a 429? And will there be any other modifications that i need to do?
i used frame brackets from a 68 t-bird with a 429 , the 68 lincoln mk3 has the same brackets. i use a 69 merc 429 rubber insulator. the engine sits just right. i could have moved it back a couple of inches.
