I am in the process of swapping out a 1995 For, F-250 5.8 L engine with a 1990 rebuilt 7.5L engine. Have engine in and transmission ( ZF, 5-speed). I messageded from the right fram to rear end yuke anf from the fram of the center support of the drive shaft and got the same measurements but when I measured from the fram to the yuke on the transmission
it was 1" wider the other two measurements. what could be wrong? the engine is setted all the way down on the motor mounts. Can I loosen the bolts on the motor mounts and pull the transmission over to the right dimension? Need help bad, this is my first time doing this and i am 77 years old. No kidding. Please answear to my email thank You
