Build your engine and test run it all on the same engine stand. Super quality for the professional or serious engine builder. Made in the USA from 3" X 3/16" square steel tubing, Heli-arc welded and powder coated. Comes with the following :
(1) Two bolt in frames to hold the Fuel tank and a battery ( not included )
(2) A three gallon fuel tank with a pick up and return bung incorporated
(3) An instrument panel with a starter button and ignition switch
(4) An electrical junction
(5) A thermostat block off plate with a water exit valve
(6) A machined brass water fitting with a quick release hose connection
(7) An adjustable rubber seal for the water pump hose inlet.
Only $495
