My engine is stumbling at low rpms, the timing is set at 14* and still pings even at WOT. Also, it smells rich. If I adjust the timing back far enough to stop the pinging, it misses worse at low rpms. This is the engine in my 65. Engine vac. is 18"hg at 800rpms. Spark plug gap is .050" This just doesn't make sense.
65 Mustang: 5 speed, 3.73's, RAP Ported GT-40 Irons, xe258hr cam, Perf. RPM, 600 cfm Carter AFB, Jacobs ignition
66 Mustang: 289-2V, 3spd, Slipping Clutch, Bashed-up Front End
<font size=-1>[ This Message was edited by: oldmustangjunkie on 1/9/02 7:34am ]</font>
