getting ready to bring out the mach from hibernation,going to get it dynoed, anybody want to estimate the power, heres what i have and doing to it now. 69mach1 408 windsor, new motorsports block stroker kit from coast, includes steel crank, eagle h-beam rods, alum pistons,10.50 comp ratio, milodon 8qt oil pan, all balanced,world cast sr heads cncd, port matched to stealth manifold,lunati roller hy,536 on both in. and ex 218 228 at.50 i know its small,1.6 rollers,750speed demon vs carb,14'' extreme k & n air filter msd 6al with 6000 rev, 1\3\4 supercomps into 3'' x-pipe into 2\1\2 2 chamber flows.alum driveshaft 3.50 posi. with 15x7 with 275-60 rear tires.fmx with 11''2500 stall shift kit. changing over to rollerized c-4.this trans will be on car when i dyno it. add ons eletric fan, maybe canton pulleys? should i put on stock wheels when i run it or keep the 15x7 on. stock wheels are 14x7 with 225-70 all around. just thought it would be fun to see who comes close. i will let you guys know when i get it up and running.timing is i think 36 total on motor. have to ck it. thanks
