1 - 12 of 12 Posts
ok its finally set in stone;
74 302
stock crank and rods
flat top pistons(stock bore)
ported E7TE heads
stock rockers
cloyes roller timing set
comp XE262 cam
262/270
218/224 at 50
.493/.500
110 LS 106 ICL
weiand stealth intake
600 cfm Edelbrock carb
flowtech headers
2.5" exhaust
h pipe
dynomax bullet mufflers
petronix igniton and coil
stock dizzy
is going in my 73 mustang coupe
weight ????lbs
T5 conversion
9" unknown ratio (stock 2.70ish?)
just wondering if anyone is running similar combo, or has an estimate on power output, or what this mess will run in my heavy @ss car
thanks
Daniel J. Ludwig
73 mustang coupe project
on hold while in MN with my gf
I love you Heather!
<font size=-1>[ This Message was edited by: fastbigblockford on 7/19/04 7:57am ]</font>
<font size=-1>[ This Message was edited by: fastbigblockford on 7/19/04 8:04am ]</font>
That's a nice street cam for your combo.
I ran almost the same combo with approx. 9.5:1 cr and got 213 RWHP thru a C4.
331, SCAT crank & H-beams,SRP flat tops,AFR 185,Stealth,Proform 750,Buddy Rawls cam,Scorpion,Smith Brothers,Hedman,Mallory,MSD....and more!!
<font size=-1>[ This Message was edited by: mstngjoe on 7/19/04 8:43am ]</font>
Well there ya have it almost my motor....differences are Im running gt40 P ported heads, Harland sharp roller rockers and 9.1:1 commpression 30 over for 306. Havent set it in stone on what carb yet...but the Bronco has a long way to go before its ready....I need a distributor, some P headers and a carb! Ditch the stock rockers and Ill give ya 300-315 at the crank.
<font size=-1>[ This Message was edited by: BRONC69 on 7/19/04 8:44am ]</font>
im glad to see posative things, if this motor would make 210 at the wheels i whould be thrilled. what would that run in a 73 coupe with full interior? gears will be changed to 3.50s before it hits the road
thanks
Daniel J. Ludwig
That is almost my set up except for the H pipe and headers. According to the desk top dino I should be making 265 hp at the fly wheel, bt you should get at least 270. With that in mind and guestimating the weight on a 73 stang to be about 3560 lb, that should give you low 14's or very high 13's.
Discussion Starter #7
i would be very very happy with 13s...just hope im not doing anything that will screw me over using this car as a daily driver. i was thinking of using nitrous, but then i know ill bag on it too hard, and i have cast pistons, so im gonna avoid the juice, for now at least.
Daniel J. Ludwig
Discussion Starter #8
one more thing, is there anything that i could change alittle to help me, keep in mind this is my only ride, and effiency is the key thing, not HP.
thanks
Daniel J. Ludwig
Discussion Starter #10
like i said, will be going to 3.50s, have a 3rd member from a pickup, pretty sure it is 28 spline to match my axles. i have all my parts except for cam and intake, and the tranny of course, but i was planning on buying a T5 off of the board. im just wondering about the exhaust, if the H pipe is the right idea for a daily driver, it just seems alot more doable on my budget. the reason i picked the carb i did is i have ran alot of 600 edelbrocks on daily drivers and they have worked out well, and throttle response is decent. i never could make a holley run as smooth as an edelbrock in a street car, just seemed like they didnt pull as clean from down low. as far as everyone's estimated, i would be happy with 270-280hp, considering i was shooting for 250!
thanks for the input everyone
Daniel J. Ludwig
Biggest thing to get that last little bit of power and effieciency out of it would be a good tune. I would spring the $$ for a dyno tune that comes with a carb tune and distributor re-curve. Make sure the dyno has a air/fuel ratio monitor. That stock distributor will have a lousy curve in it for your engine and the chances of your carb being just right out of the box are pretty slim. Plus with the dyno tune, you'll know you're not running lean anywhere...
Discussion Starter #12
Neal,
once the car is assembled and the engine is initially started and broken in, it will come to college with me for an afternoon of tuning on the Dynojet, we are able to monitor air fuel ratio, plus they have a way better timing light than me(snap-on). only thing i will need some help with is the distributor, as far as getting the curve right and all. the carb will not be a new in box one, it will be one that i have, rebuilt and tuned for my setup. i have rebuild a ton of E-brocks, and there is nothing to them.
thanks for all the help
Daniel J. Ludwig
1 - 12 of 12 Posts
