I read a post a while back that mentioned putting a rear sway bar from a late 90s Explorer on the 64 and prior Galaxies. I may have access to one and I am going to try it. Does anyone have any experience retrofitting this bar to a different car? I figure I can get it pretty cheap and it will be worth a try.
Not yet. I got caught up in an engine swap on my 86 Mustang and had to hold off on it. Since the 86 is my primary means of transportation it took priority. I do have the sway bar and I still think I can make it work. I will have to cut some brackets and weld them to the axle tubes to mount the bar. It is a compact piece and it should not be a problem.
