any fox V8 header ? should fit , but there could be some major problemsgot a 79 fairmont,straight 6,going to do a v8 swap with the truck mount set up.will any long tube header from a v8 fox work, as in bbk,hooker,ect...? thanks homies...
when you try it , let us know how they fit .im fully aware of the v8 k member swaps..... i was asking if the fox v8 long tubes such as the BBK's will fit the straight 6 k member using the truck engine mounts.ive seen truck mount used withe the 6 member.i would like to know if long tubes will fit.
