last thing i have to do is repair small rot on bottom of rear window ,have to remove rear window to do this.I removed trim and am unsure about how window is installed,is there a rubber gasket or is it glued in ?It looks like black silicon seal ? or a really old original gasket ?what is right way to re install with also the spring clips that hold moulding in any idea where i can get them ? thanks
GLUE strip thanks ,any idea who would have them? or is it in a tube ? dearborn and macs are a little confusing with description not sure if it is the rear window seal they are selling. I did find the clips in dearborn ! thanks again
