Hi everyone!
My car is a '68 Mercury Park Lane with a 390. I'm running a Holley 1850 4 barrel, and the stock points-based ignition.
It runs hot all the time. This I've deduced from the dash light. "HOT" it tells me. Pretty much all the time. I've got gauges on order so that I can figure out HOW hot, but the plugs are white, so I think it's safe to say that we're too hot. The cooling system is full with 50/50 water antifreeze mix.
I've read in various places that the voltage at the coil should be 9 volts, and is stepped down by some kind of resistor? I'm running 12 volts, as measured at the positive pole of the coil.
Could that be why I'm running too hot? Is it possible that the resistor unit is still in the car, just wired out of the system by a PO? What do I look for?
Any insight is appreciated.
68M
68M
