I'm restoring my father's 64 Galaxie 500 XL with a 352 4v. I'm planning on routing the coolant lines through the carb' spacer, as per factory build. Just wondering if there is any benefit to this or am I going through a lot of trouble for nothing?
I needed the spacer for the PCV (1965) but removed the hoses. Instead of plugging the fitting at the intake I tapped it and used the tap for a water pressure sensor. Originally the hot water was to prevent carburetor icing but where I live that is not a problem.
After doing some research, I found out that running the water through the spacer also acts as a heat exchange, by warming up the fuel it helps it atomize it better in the combustion chamber, leading to a better air to fuel mixture, resulting in a better burn. Doesn't give that much more power that I can tell, buy hey, I feel smarter repeating it.
Correct. It is more of a cold air measure. The fuel mixture is heated allowing the gasoline (atomized) to stay in suspension. The heat riser feature is another cold air feature. This (heated spacer) was later replaced largely with heated air inlet.
You would want to keep it for an everyday (every season) driver but maybe consider bypassing it for a performance engine.
The guys with the big six seem to always add this to their performance manifolds to maintain optimal drivability, especially when cold. I'd keep it unless all-out performance is your main goal.
Does not seem like a plausable answer. By the time the radiator water gets hot enough to warm the spacer it's too late. The manifold has been hot and doing the job for 15 minutes - that is what the exhaust crossover is for.
Plus the surface area of the holes through which the air speeds through the spacer is miniscule (like 1% compared to the surface area of the intake). A very non-Ford spending of money for a micro-teensy bit of effect.
The reason I say it is to prevent carburetor icing is its location. Carb ice builds up on the walls just beyond the throttle plates, which is exactly where the spacer is. The warm water keeps the ice from building up there.
Just my take on it.
