hello, i have a 70 390 i am putting in my 63 galaxie, i do not have the 63 flywheel, does anyone know if i can put a 153 tooth ring on a later model flywheel, thanks
Steve, you can put the 153 ring on the later flywheel, but it will be better in the long run if you use the 1970 184 tooth flywheel matched with the 1970 starter. The later model starter will bolt right in the 63 bellhousing.
