Hello,
Trying to clear room and lighten the load. Here are a good set of FE heads and 4 jet intake, as well as gaskets and the bolts.
The heads are C6AE-U's. The guides are serviceable as well as the valve-seat interfaces. See pics below for details.
Here's what's included: both heads, intake, head bolts, intake bolts, rocker shaft bolts, head gaskets, intake gaskets, exhaust gaskets, thermostat gasket and distributor gasket. The valve stem seals in both heads are brand new as well.
See below for further detailed pics.
Here's one head.
The other head:
Intake:
The intake, heads and bolts are lightly covered in oil to prevent oxidation then bagged and it's all boxed up.
The price for everything is 600 dollars.
Cheers
