FE inspection plate gasket?
441 Views 3 Replies 3 Participants Last post by  5851a
4
Hey guys,
As I was cleaning up my inspection plate/cover for my 65 390/MX bellhousing, I found remnants of what looked to be cork gasket material. Were these supposed to have that from the factory (my parts catalog is a little unclear on that)? Also, I saw a rubber starter dust boot/seal on ebay for 390 with a '62 part number, made me wonder if these were supposed to have that. I appreciate any help, and sources for purchasing, if they were stock and are available. Hoping to make this as correct as possible.
Thanks,
Kelly
Automotive fuel system Automotive tire Motor vehicle Fuel tank Automotive design
Hood Automotive tire Motor vehicle Automotive design Automotive exterior
Tire Automotive lighting Automotive tire Motor vehicle Vehicle
Automotive tire Motor vehicle Automotive exterior Rim Asphalt
See less See more
  • Like
Reactions: 1
Dang Jazz that is a clean MX. I have my inspection plate off and don't see any gasket stuff. but it's a rebuild, so maybe it was there once. Also, I don't see them being included in rebuild kits.
Would you mind taking a few measurements for me? The length of the transmission and the length of the driveshaft. Thank you!
  • Like
Reactions: 1
Definitely will do. I’ll try to get to it tomorrow.
Rubber starter boot ended with the old style starter in 64 I believe.
