1 - 11 of 11 Posts
I bought them from Anthony over on the FE forum years ago and got to thinking, why not?
These things practically put themselves on. The only bummer was that I broke off a bolt on each side, so I am running a small c-clamp on those two.
The motor is a stock half-tired '65 352 bottom end and a set of the faster burning chamber C8AE-H heads with a port matched Performer. The carb is a Frankenstein I built from a Carter 750 CS body and an Edelbrock 800 AVS top set up as follows:
Floats: 11/32" hieght, 1 1/4 drop
Pump: 13/32"
Jets: Pri: 107 w 6537 rod Sec: 104
Springs: Pink cut-in 7 hg
Idle screws: 2 1/2 out with open headers, will likely trim to 2 with exhaust
It is jetted safe until I figure out how the unequal length tube headers are going to act.
The distributor is still points but I recurved it. It had a 13L centrifugal slot, (13° of distributor timing or 26° of crankshaft timing)so I shortened it with some epoxy to 10°/20° because I was too lazy to dig out another distributor
Initial is at 15° for a total of 35°, and I have the vacuum advance adjusted to take it up to 53­° with no load.
Got my historic license plates in, so its time to do some historic testing
Do you have an automatic? Power steering? I have the old log exhaust manifolds on my '62 and would consider headers if they fit a 352 w/ power steering and went in as easy as they did for you.
Mine is a '65. But yes it is an auto and PS. I am certain the earlier ones fit the same, its just a different part number. Here's a link to Crites.
http://www.critesrestoration.com/galaxie.htm
These are big primary tubes, 2". Theoretically they should be too big for a stock engine, but eveyone I know who is running them highly reccomends them especially the quality and ease of fit for the money.
1965 Galaxie 352 Cruiso
1965 F250 4X4 390 4-speed
Subtlety is only a matter of choosing the right hammer.
<font size=-1>[ This Message was edited by: BillBallinger on 6/3/06 9:45pm ]</font>
are these the ones?
1965-67 Galaxie and Mercury with FE auto trans. & PS - $329
My Gal is 65 352 A/C A/T P/S. the whole exhaust system is getting a little ragged so I am thinking... Let me ask you this. Is the chief benefit of the headers vs manifold looks or power? how much are we talking about?
I am thinking one day I will bore or stroke my 352 so maybe just replacing the current manifold won't be so good. Is that the value of headers, not current HP but potential for expansion?
after copy and paste remove the fordmuscle part and type in network54, then it will link.
This thread and its unique predjusticed filter is LAME!
Humph..
<font size=-1>[ This Message was edited by: wildosvt01 on 6/16/06 7:48am ]</font>
No workie because of the childish filter this admin has put here.
N e t w o r k 5 4 . c o m
F o r d f e . c o m
Simply type in first one w/o the spaces. Then paste the forementioned remainder of the link. Brought to you by yours truely. On the other site my avatar says it all. BTW I STILL WOULD NOT GIVE CHARLES ONE F-IN DIME OF MY DOUGH until he learns to use a ruler!
1 - 11 of 11 Posts
