I had my 05'GT in the shop for a nitrous installation this week. The tune produced a 276.69hp and 292.52tq. With the nitrous it produced 361.19hp and 369.88tq.
My question is, How good are these numbers? The car is an automatic with a cold air kit and cat back magnaflow system and now nitrous. What would I expect to see with with pulleys, charge motion plates and an off road X pipe? How close to the limits of the stock block would I be? I have read the 4.6 block will only handle about a 50% increase in hp?
300 hp stock x 1.5 = 450 hp. Looks to me like you still have about 100 to go.......................More Seriously some guys are making in the 600-700 hp with stock 4.6 blocks, they are pretty stout. Your dyno numbers appear to be pretty close as what to expect.
FYI: the block is not the weak link, it's the rotating assembly. In particular the cracked, powdered metal rods = junk. 400 rwHP is the approximate max., so it sounds like you've got a safe tune.
The pistons would be the next weak link as they (and the crank) are cast pieces.
Does the Cobra engine use different crank/rods? I've seen numerous mags doing supercharger/turbo tests making well in excess of 800hp(!) and they never threw a rod.
