First time rebuilder here. Finally got to take the car out for a testdrive before handing it over to the shop to get new exhaust in, but it didn't go to good.
engine is:
351c std bore, honed, new rings, bearings. Aussie 2v. approx 11,5:1 comp. Comp cam S282, Roller rockers, Weiand 2V excellerator. Romac balancer and TCI flywheel, Newly rebuilt C6 and TCI torque converter. Restrictor plugs installed.
Got about half a mile down the road and got up to 50 mph, when it started sounding like exhaust hitting the bottom. Let of the gas and turned around and slowly started accellerating again, now it sounded alot louder so I shut it down and pulled over. Suspected newly installed fan cover, but it wasn't. Started engine again and I could hear it comming from passenger side cylinder bank. Oil pressure were fine, about 30-40 psi Thought rocker nuts backed off and several rockers hit the valvecover. Walked back to my garage and picked up some tools and pulled valvecovers. They were rocksolid bolted down. Bummer! Called a friend and he helped push the car back to my garage.
My guess is either of following:
1. Maincap or rod bolts backed off
2. Broken piston rings. (but still, no smoke)
Any other suggestions?
<font size=-1>[ This Message was edited by: cyberhawk9 on 4/26/06 5:22pm ]</font>
<font size=-1>[ This Message was edited by: cyberhawk9 on 5/8/06 1:22am ]</font>
engine is:
