1 - 12 of 12 Posts
Got a trip to Silver Dollar planned this weekend and I'm looking forward to trying out my new Vic Jr. intake. I've only driven the car a few times through the neighborhood with the new intake and it seems to run very strong.
I didn't change anything in the carb but I feel like there should be a need to rejet it. I'm sure air flow thru a Vic Jr. and a Stealth intake are very different which would yield a need to retune my 750 Holley. Should I fatten it up? Lean it out? Or am I just over thinking it? I want to say it has #73's in the primary and can't remember the last time I was in the secondary bowl. I presume maybe #78's or so?
Anyhow, with the cooler weather, I'm hoping to stay in the 12.80's and shooting to dip into the 12.70's and hit 110mph. PB now is a 12.88 @ 108 with the old setup so hopefully I'm not too far off.
Test N Tune is Friday night and after that I'll be heading up to Road Atlanta Saturday and Sunday. Reckon I can see what those guys use that steering wheel thing for ;)! I'll try and post some videos and time slips and share some road race pics!
I think the trend is leaner with a single plane intake so I am not sure if you will need to rejet or not..I would listen carefully when you make a pass (for lean misfire)and check your plugs after the run.....Sounds like you need to start keeping a race journal so you can remember stuff like jetting or timing,launch techniques etc...Another trick is to stick a small piece of duct or masking tape on the top of each fuel bowl on your holley and write the jet numbers on the piece of tape.....BE CAREFUL turning corners! :D
Thanks frdnut. I try and keep my setup in my head but with school cramming all kinds of new stuff in, that info seems to be finding its way out. That's not a bad idea though.
So you're saying I should bump the jet sizes down a bit?
This might sound like a noob question but how exactly do you read the plugs to see if they're fat or lean?
Also, I plan on uncorking the headers to make it breathe a little better.
...And don't worry, I'm not going to be the one doing all turning, just riding along.
As promised, here are some videos from the weekend.
This was my second pass and new personal best! 12.63 @ 107.9!
My million dollar time slip!
Unfortunately, I wasnt able to tune at all. Honestly it really didn't feel like it needed it. I let my buddy drive the car and he made two passes.
At first, I thought he grenaded 1st but apparently, he said it came out of first? Never happened to me before.
His next pass, he was out of the groove and didn't do a good enough burnout and the car lurched toward the center of the track. Scared the living dog $h!t out of me!
The next pass, I hit second and heard a bang. The elcheapo tranny mount let go. No big deal but it put an end to the night.
Like I said, I also spent Saturday and Sunday morning at Road Atlanta. It was pretty busy between diagnosing a blown head gasket on my buddy's foxbody and running back and forth between the paddock and the track. Wasn't able to take any pics but we had a lot of fun. Coolest car at Road Atlanta was a dark red Daytona Coupe kit car that had a 408.
Discussion Starter #8
Thanks guys! I really wanted to make more passes but I was held back by broken parts. Like they say, "If you're not breakin' ****, you're not trying!"
I am 100% sure that the Vic Jr. is what made the difference. Still without any tuning it pulled very strong. I had three good passes and it actually hung the LF hoop (as dennis would say ;) ) and carried it a bit! The cool weather always helps, I'd say it was in the low 50's or so and had rained the day before. Track prep was incredible. Every time I rolled up to the tree after a burnout, it sounded like someone was peeling up industrial strength duct tape :). That could be why the tranny mount let go.
Not the best quality video (camera man might have had a beer or 3) but I'm in the far lane. It let go when I hit second
I'm thinking about putting a 6200 chip in it now. When I crossed the stripe, it was bouncing off the 6000 chip. Maybe could have squeezed a 108 mph out if it wasn't. Just don't know if I want to spin it that high. Also considering re-ringing the bottom end. That is one thing that I have not touched since I've owned the car. Supposedly when I bought it in '06, it only had 5k miles on a rebuild. Don't know how reliable that is because I popped a head gasket 6 months after owning it. The motor only makes 125psi on a compression gauge and #4 only makes 95-100psi.
Good quality, up close shot but my buddy didn't record the launch! Ahhh I gotta train these guys!
Wow it sounds like you need to freshen up that shortblock...I remember my first clean pass with my new 408..I was also running a 6000 rpm chip and was kinda startled when it started missing badly at about 1000ft or so..The 6 grand chip had worked just fine with the old 302 and 100 mph trap speeds..Not so much at 120+. :).....You will either have to go for the 6200 or bump up your tire diameter a bit..
You might be suprprised how much et there can be jetting on a motor that seems to be happy. I found about .25 and 3 mph in mine.
Discussion Starter #11
Right now I feel so far away from 120mph lol. It is getting to be time for new tires. They're 255/60/15 drag radials. I've run 28x10.5 slicks but it bogs real bad off the line. I like the way the smaller tire gets out of the hole.
You think a stock/tired bottom end is safe to spin to 6200?
Oh believe me, I know what you mean. Being a broke college kid for the past 4 years, I've found plenty of ways to shave time with tuning rather than throwing piles of money at it. ;)
Those drag radials are going in the wrong direction. If you need a shorter tire, then get a 26" slick. MUCH better drag tire than a 255 drag radial!
1 - 12 of 12 Posts
