Here is a pic of the pan installed with tack welds and plug welded at rocker.The pan is butt welded a perfect fit. floor repair 011.jpg After tack welding all the way around move back and fourth to keep heat down.I used .23 wire on this job and keep the heat setting on the lowest setting.floor repair 004.jpg Here is a pic with the floor pan installed from the bottom.
floor repair 013.jpg After all welds are ground down I like to use brush on seam sealer and rub into seam both top and buttom. floor repair 016.jpg floor repair 017.jpg Well ther you have it,I spent about 5hrs with this repair with a little sanding and paint the seam will disappear...ED floor repair 019.jpg
