I have a 65 Galaxie convertible with loose sun visors that flop down while driving. There does not appear to be an adjustment screw anywhere to tighten these down. Any ideas on how to fix these? Does the entire visor/sleeve need to be replaced with a new one?
This works sometimes.
Pull the Visor (rod) bracket out of the visor and get a pr. of pliers and put some deep gouges in the rod. This will give it something to bite on when you reinstall the bracket back into the visor.
If careful you can also get the pliers and bend down on the visor a LITTLE with the bracket (rod) removed and this sometimes will put extra pressure on the rod when reinstalled.
I have also got a hammer and hit the rod in 3 places and made it egg shaped a SMALL amount and that would also work. Just don't make it to egg shaped before you try it out first.
