On 2006-05-08 21:02, 71hotrodpinto wrote:
OIL + FIRE = BAD
As a last resort drain the oil use some 60 or 36 grit paper on a angle grinder or the like, and some acetone or brake clean ( not carb clean) to clean the outside. Then use some jb weld to "glue" a small patch of sheet metal over the crack. THEN "seal" the patch around the edges with some more jb weld. If the crack is not on a flat surface you can gently shape it with a hammer till its approximate.
Im almost positve that it will seal IF you get the surface ROUGH and CLEAN. And do it when its warm outside. if its cold it will take forever to dry and it will probably run all over the place.
I second this approach, sounds like you have backed youself in a corner. Been there broke on it...we only reserve the car fires for the bow tie boys, ok?!? LOL
No one likes to hack stuff, but sometimes you have to do something to get by.
I would degrease the pan spotless, grind the pan with a flap wheel on a grinder, clean the area to bare metal, and then JB weld a patch on it. If you can, get a clamp from a hardware store, and use it to keep pressure on the patch while the jbweld cures. As a last idea, take and use some copper seal gasket maker {in the squeeze tube} and maybe lay a bead around the ouside edges...probably won't be the beauty contect winner, but it sounds like you don't have a prom queen virgin, either.
Just trying to help.
If you proceed with the braze method, do it outside on the driveway, and have atleast some way to put the fire out, like an extinguisher and a couple boxes of baking soda and worse case a garden hose.
Garden hoses work wonders when welding on a roof skin and setting insulation on fire...
