Has anyone tried their $65 conversion crossmember and isolator? Curious about going this route vs. fabbing an extension plate for my 63.5 390 floor shift.
It's the two bottom pieces. Sorry for the small pic: https://drive.google.com/open?id=1YkwKNyB70sOP9EQE2XOqDG2qB1fdXmni
I found a '67 C6 column shift, hoping to crack it open, send the VB to Broader, rollerize, etc. out in the garage sometime "soon".
If you’ve not seen already there’s an awesome post on here how to set up roller thrusts.
if you need help sing out I’ve done many.
Thanks! Sorry, not sure why I just saw this notification. I just purchased the above mentioned kit.
Any idea how much loss the rollerizing saves?
Discussion Starter #4
The Crites kit has a piece of angle iron with hand cut slots, but they are so misaligned that I only get 1/4" adjustment. I requested a new bracket, else I'll file the crap out of this one. Will also be upgrading to grade 8 washers and lock washers.
Greg, do you know if I'll need a new trans side yolk and if so, which one? Thx!
