Had my trans out to reseal. It was working fine before but leaking at each end. Now it is slipping instead of going into 3rd. It was fine around my house but after trying to get into third I noticed that it was also slow going into reverse.
To reseal between the case and tail housing I had to remove the governor and a couple of other parts.
Is it possible there is an issue with the governer that would impact reverse? Did i break something in the trans?
It was hard to pull everything back to get to the the gaskets. I did have to pry and hammer a little.
It looks like Inhave the fluid back up to where it should be after draining the pan.
