FOR SALE: 1956 F100 Custom Cab…running project
Due to unforeseen circumstances I must part with my F100 project…
Bring a trailer and cash and it’s all yours….
Selling as a package. Asking $10,000 or best offer…
I have much more that this in the truck AND NEW parts!
1956 F100 --- Red with White top original 2-tone paint
ALL ORIGINAL truck inside & out except for motor & transmission…
302 – 2-bbl AND C4 transmission pulled from a wrecked 1970 F100…includes extra C4, got it with the truck!
Fiberglass front fenders…they where installed when I purchased the truck!
PARTS LIST: NOT installed...most NEW in BOXES!!!
2nd set of original rear fenders with spare tire cut-out on driver side fender ---almost NO rust
1970 F100 9-INCH rear axle housing with all brackets removed & cleaned up
Ford 9-inch Big (Torino) Bearing Rear Disc Brake Conversion kit…. rotors are 5 x 4 ½ Ford pattern…
Ford Racing Parts # M-4204-F28A, TRAC-LOC Limited Slip, with 1536-steel billet case caps
ALL bearings & gaskets needed to assemble rear pumpkin….
NASCAR Ford 9-inch 3:89 ring and pinion set --- Back-cut gears!… from a NASCAR
team down south....was told it has 1 400-mile race on it...looks PERFECT!
New Dutchman 28-spline Street/Strip axles & retainers with bearings…NEED axle SEALS!
Extra “hooded” Daytona pinion bearing support without races/bearings
1956 Running boards --- need a few repairs
2nd set of “short” cab-length running boards…I was going to use these to repair the long ones!
Total Cost Involved Mustang II style independent front suspension with tubular A-arms and air springs with sway bar…rotors are 5" x 4 ½" Ford pattern…
No Limit Engineering FAT BAR 4-bar parallel rear suspension with air ride, includes panhard bar!
Accuair Stage II management system with ride height sensors, key fobs, EVERY option available!!!….best of the best!
VIAIR 400C Dual Performance Value Pack compressors…recommended by Accuair for their systems!
12-gallon 8-port D.O.T.approved air tank for air ride system
Art Morrison Enterprises 2" x 4" square steel tubing for NOTCHES…..bent the “hard way”…you can view them here……
http://artmorrison.com/layout.php?y=frames/&x=framekit
Look for a section labeled: Special Bends Also Available!
ALSO AVAILABLE!…
Probe Industries SRS #10666-030 flat top pistons Net Head Volume (cc) -4.0.
...and...
Clevite Perfect Circle Ring Set: #315-0049-030 1/16" - 1/16" - 3.0mm (std. oil ring)
Early 60’s SMALL BLOCK FORD Buddy Barr/Holley TRI POWER set up!!!
SOME PICTURES HERE...
http://s88.photobucket.com/albums/k200/rockher_man/1956%20F100%20PROJECT/
ALSO AVAILABLE!…
...and...
