what marks go where on the top gear of the gear drive there is A- then- R and -O and the 3 holes in the gear drive what one do i put the pin on the cam in any help would be really appreciated thank you
If you have an aftermarket performance cam, keep in mind many manufacturers grind their cams with advanced profiles. The only way to be certain is to degree the cam to make a decision on which way to go. My preference is to run it straight up.
Joe
