I was told I could make a ford aod multiply torque in a 4 gears, short of installing a sprague eliminator I cant figure out how thats possible. Does anyone here know how you can do that?
Discussion Starter · #2 ·
Never mind on that, I figured out that if you were to cut the direct drive shaft even at the input shaft and welded in place, you can get torque multiplication without having to lock the stator in place. TCI makes the kit for it in case anyone was interested in the answer
