Same principle of the Chevy LT1 engines. And they weren't all that special.
But, if you can do it, go for it and keep us updated. Basically you'll want to reverse the flow. In the manifold, out the block. Simple. Or, you could just fill the block with grout and run water through the heads only..just like I do. Not recommended for street use that way though.
