well I have been hearing a slight really faint knock on the passenger side of the rear block after the car gets warm at idle. it goes away under any throttle.
SSSOOOOO I went on a witch hunt with the sawed off broom stick. checked the converter bolts and they are all tight.
well the knock can only be heard through the manifold and was worse on the back #4 cylinder. Couldn't hear it through the heads or anywhere else.
Heres the scary part. It stops when I unplug the #4 spark plug.
I am running 10w30 castrol and was told to run rotela T 15w40 today by the engine builder.
The motor was built again 6 months ago because it wore out a cam lobe. he said he went through everything. all push rods are strait and the top of the heads look perfect.
Heres my ideas.
Worn wrist pin
clearance issues with the crank bearings
cam lobe shavings got in the #4 crank bearing
maybe the cam is wearing again, but usually this causes missing. "CAR RUNS LIKE NEW THOUGH".
So what should I do. Run it until it gets worse? try the rotela T 15x40? tear down the top end and check everything I can? I am a little sick about it but I feel like I may have done it being rough on it one day lol. Its already bored 60 over so a new block will prob be needed if I let it go. I think the 60 over bore and 10.1 pistons may be part of my overheating problems also.
As always any thoughts and reply's are high appreciated
Heres my ideas.
Worn wrist pin
