Has anyone tried to retrofit a Fox 5-speed pedal assembly (all three pedals) into an early Falcon? It sure would cure what ails me, and for cheap!
I've heard that the only one that will fit properly is one from a Falcon. But, that is just hearsay.
i did it in my 61 falcon, the clutch and brake pedal assembly came from a 91 gt mustang. i used a lokar throttle pedal and cable. the pedals take some fabrication as far as mounting and bracing but nothing to crazy. its definitly not a direct bolt in, although im happy with the results. the fire wall will need to be braced as it will flex when you depress the clutch pedal, the cable pulls on the fire wall. the brake pedal lined right up with my master cylinder, i did have to adjust the lenght of the brake push rod and i used a ford motorsport adjustable clutch cable and firewall adjster to get the pedal hieght correct. i also used the brake switch from the mustang pedals and wired in my brake lights. i will try and answer any questions i can.
