1 - 9 of 9 Posts
· Premium Member
They are nice, I have used them on a few different applications. Sometimes the ball and socket can be real crowded underneath, especially on Fairlanes for some reason. With a small block car it should work out well
They will fit your car and they are a perfect exhaust port match for afr 205's. 1 3/4" tubes, do clear lakewood bellhousing. Specify what size exhaust you are planning when you talk with Stan, I believe he has different size collectors available.
Just ordered a set from stan for my stroker combo friday, he's a great guy to talk to. Mine are for a 70 mustang with a 351w and afr 205 heads with a lakewood and 3" reducers. He said they'd bolt right up and I wouldn't have to do a thing to them. They'll be here in about 3 weeks, but I won't know how they fit until I get the rest of the motor together. I also had him ceramic coat mine with the polished aluminum look. Can't wait to see them!!!!
FPA's headers are top notch... and so is Stan! He worked with me on a set for my '72. Same header as the '67-'73 Mustang/351W. Couldn't fit more perfectly, even with the C6! Stan told me of any possible interferences that could have popped up during install and how to remedy it... ahead of time. The ball and socket collector definitely was the way to go, too. Just be sure he knows exactly which head you're using, and what size exhaust you want to run from the collector on back.
All in all, a great product and some of the best money I've spent. Period!
Kevin
1 - 9 of 9 Posts
