1 - 20 of 27 Posts
has any one got a link to a diagram of what clip goes where on the front fender mouldings on my 63 country sedan , i have just had the front end sprayed and bought 2 sets of trim clips from greg donahue but as trim was held on with evostick to fender i have no reference where each clip goes .
sadly my drivers side trim has been so badly cut up and butchered i need another one , i dont suppose anyone knows where there is any trim ?.
thanks in anticipation mark in england.
You can find the clips and placements either in the MPC EXTERIOR MOLDING SECTION or an ASSEMBLY MANUAL.
it looks good but when i make it big enough to read its to blurry , might be my eyes as i am 50 in 3 weeks lol
The man is on it... :tup:
On the Ill, the two characters in the circles will cross on a legend that will give you the PN's of the clips. Placement is obvious.
That molding may be able to be repaired. We have specialty shops on this side. With all the JAG fans over there, there has to be a stainless specialty shop.
there are but its anodised alloy sadly otherwise i would weld it
You may be able to find the piece used.
I forgot (bad manners)-
MERRY CHRISTMAS to you, yours and the QUEEN...
Exactly which piece do you need?
BODY CODE?
Discussion Starter · #15 ·
i need the front fender moulding that run from door to front of fender on left hand side/drivers side of a 63 galaxie/station wagon
pride the no is on the warranty plate, and although you described what you have some of those cars depending on BODY style NO. the trim is actually different, even if at a glance it looks the same.... FYI.... The body no will be the deciding factor which type/kind/style of trim you are needing...
Shown below is a 1962 FORD plate but you will see the three character code over the word BODY.
63 country sedan.
its (BODY CODE) 71b
LF FENDER CENTER SIDE MLDG- BRITE - C3AZ 16004-B
Actually, this mldg fits all 1963 applications that came through with these center side mldgs.
(54A - 62A - 63 - 65 - 71B - 71C -75 - 76)
These Body Trim Codes will be explained in your appropriate year OEM Shop Manual.
1 - 20 of 27 Posts
