Well, something new has popped up on this '68. I'm sure there's a simple answer but since I usually over-engineer everything I can't see the simple.
When I set the hub on to the spindle, the inner seal is rubbing on the facing edge of the spindle causing the hub to take an enormous amount of effort to turn.
I'm sure the inner bearing is supposed to come against the bearing stop before the seal hits that face but it does not seem to be the case.
Inner bearings are a Set 6 (LM 67010 race, LM67048 roller) and the seal is a 6715 and they are all new.
I have checked Mustang hubs thinking that these may have been swapped out but those call for the same bearing set. The six cylinder cars used a smaller set but there is no way those will correct this.
Has anybody run into this issue? What am I doing wrong? Could I have pushed my inner races in too deeply? Seems like I need about an 1/8" to 3/16" wider bearing.
Thanks for your help.
Murff
Murff
