I started on the front end rebuild on my 64 Fairlane today. After a little excitement when the coil spring compressor broke, (Holy crap!), I managed to get the passenger's side apart after a lot of work. The upper control arm is done and reinstalled with new shafts, bushings and ball joints.
Do the lower control arm bushings need to be pressed out and back in or can I drive them out? Also what is the easist way to cut the rivets on the ball joints so I can bolt in the new ones?
