If its realy stuck let the oil sit in the cylenders a day or two. Dont put the plugs back in to turn it over. but if you going to let it set a day or two put the plugs back in just to keep dirt out..
tim
WARNING* This car is a Sleeper, and is NOT powered by the infamous 170 ci, 105hp weakling you all know so well... It is Powered by the Mighty Power of a .040 Over 202.6ci 1 1/2" 1bbl, POWERHOUSE making nearly 123.6 hp! I'LL SMOKE YOU!
LMAO!!!!!!
· Premium Member
I used some pb blaster and coated the inside of the cylinder with the straw attached. let is sit about 30-45 minutes and took a large 3/4 drive ratchet and broke it loose.
