I recently swapped out the original engine and transmission in my 1964 Ford Falcon, and have them sitting at an auto shop in Inglewood, CA. These are 5 bolt pattern, and come with the trans yoke, damper, intake, distributor, pulleys and brackets. The flex plate and block plate aren't there (we used them on my car). Neither the distributor or intake are original. The timing cover is included but had a crack across (it's in pieces). The bellhouse and trans are one piece (does not unbolt).
Unable to tell if the trans has ever been rebuilt, however the engine does not appear to have been rebuilt. Everything was running great, I just dropped a larger engine in there, and wanted a transmission with more than 2 gears.
$2000 for both, obo
$2000 for both, obo
