1 - 8 of 8 Posts
I have tried 3 fuel gauges, including a new one and they all show more fuel than is in the tank. Anyone know the problem or fix? thanks
no no no no no....... You've got to conjugate your Verbs!
Did you try BENDING the float rod to adjust the position of the float in relationship to the position of the pointer on the rheostat....
That will cure the wrong amount issue every time!
You might not get it perfect but it's good to the 1/8th tank if you're good!
FE
Thou Shalt NOT Mock My sissie Falcon!
<font size=-1>[ This Message was edited by: FEandGoingBroke on 7/28/06 11:16am ]</font>
I'd seriously consider putting in exactly 1/2 tank of gas then removing and installing the sending unit and manipulating the float rod until you get it right!
Saves you a shat load of money....
The voltage regulator on the dash <U>might</U> be for the operation of the fuel gauge but I doubt it, it should run off of 12V not 6 or 8V.
The rheostat on the sending unit is where the gauge get's it's signal, and they're pretty much going to be the same across the board if it's made for your '67, well, it's made for your '67.
Trust me I'm a Doctologist....
FE
Sounds like a good plan to me!
Not everyone is cool enough for Air Shocks LOL!!
<font size=-1>[ This Message was edited by: psivory on 7/29/06 12:21am ]</font>
Discussion Starter · #8 ·
Who sells them and do you have a part number-I don't see it in the wiring diagram. Thanks
1 - 8 of 8 Posts
