438W with Mass Air Flow EFI made 520rwhp and 457ftlbs through a C4 Trans with reverse manual Valve body, 3800 stall, and 411 gears in a 68 Mustang.
SVO block 4BOLT MAIN on all 5 caps splayed.
Scat H beam Rods with ARP 2k bolts.
Mahle forged pistons 11.35:1 compression.
Scat Forged Crank.
Total seal rings.
Clevite Bearings.
Super Victor Intake
Comps Cam Billet Xr292r on 112 LSA.
AFR 220 Heads.
Manley springs.
Comp cams Ultra pro magnum rockers.
Isky Bushed Lifters.
Mass air flow efi with Eddy high flow elbow, Accufab 90mm TB
80lb injectors.
C4 Trans
3800 stall
410 gears.
All on 93 octane. Car is e85 compatible for future Paxton install.
Scat Forged Crank.
Total seal rings.
Clevite Bearings.
Super Victor Intake
AFR 220 Heads.
Manley springs.
80lb injectors.
C4 Trans
3800 stall
410 gears.
